6ft garden boundary wall
Stuart_253
by Stuart_253 » Mon Jun 18, 2007 7:17 pm
I want to build a single width garden wall with pillars 15 mtr long x 2 mtr high using standard concrete blocks 440 x 220 x 100. Using the foundation calculator I came to a staggering 82 Kn load (this includes 30Kn wind load based on 1 Kn per Sq Mtr). The soil is compact and will require the use of a pick axe. After all this I'm still struggling to decide depth and width of my strip foundation. Could you please advise.
One final thing, again using a calculator I came up with a total requirement of concrete to create a foundation as follows based on a .5mtr depth x .5mtr width & 14mtr length.
Cement = 1.2 tonne
Sand = 2.2 tonne
Gravel = 4.5 tonne
Is this about right.
Apologies for asking so much but just want to make sure everything is in place before i commence. If you can help with this your definately on my Christmas card list. Thank you.
thedoctor
by thedoctor » Thu Jun 21, 2007 9:00 am
Your foundation only needs to be 150mm deep Stuart, not 500mm and for a 100mm wall the width only needs to be 400mm. The ideal mix is 6 to 1 which, as the calculator shows on your previous entries, is about right. All of the above only applies if the bottom of the trench is solid ground.
It is currently Sat Nov 23, 2024 7:16 am
