Use of sailicone sealant on inside window frames
Jerseyconsumer
by Jerseyconsumer » Fri Feb 25, 2011 5:30 pm
Why has my builder used silicone sealant on the inside of my PVCu window frames to seal reveals etc rather than a paintable one? I thought silicone sealant was only used outside as now when I want to re-emulsion I have difficulty getting a good edge.
silicone
by welsh brickie » Sat Feb 26, 2011 6:15 pm
he should have used acrylic sealant.
Jerseyconsumer
by Jerseyconsumer » Sun Feb 27, 2011 3:39 pm
Thanks- that's what I thought. There are paintable frame sealants for inside use which makes it much easier to re-decorate.
JRS
by JRS » Tue Mar 01, 2011 8:15 pm
Just being to lazy, He should have used decorators caulk. I really loathe this.
chris_on_tour2002
by chris_on_tour2002 » Thu Mar 03, 2011 10:52 pm
if the silicone is only filling a gap then you should be able to peel it off and refill with a caulk. it may be that they have used it to adhere the trim.
It is currently Mon Dec 23, 2024 1:35 pm
