Type of plaster
panza
Type of plaster
by panza » Wed Mar 30, 2011 8:59 pm
I have recently had some electrical ring circuits extended and new sockets installed resulting in significant areas of existing plaster needing patch repairs.
Can anyone suggest the best plaster to use for the job. I have been told that thisle is a good brand so was thinking of thistle hardwall + multi finish. Alternatively, are they any good one coat options on the market?
The background material is block in some places, brick in others.
JRS
by JRS » Thu Mar 31, 2011 6:49 pm
Thistle is the main one dont know any other plasterer that uses anything different unless you are just using a filler like fast set. made by gyproc.
plaster
by welsh brickie » Fri Apr 01, 2011 7:23 am
thistle 1 coat
chris_on_tour2002
by chris_on_tour2002 » Sat Apr 02, 2011 12:04 am
if i were you i'd use thistle bonding plaster to fill the holes then just a normal polyfilla (powder form - not ready mixed) to skim and finish. at least then you can sand it back to a decent finish.
most electricians use one-coat plaster if they make good their own butchery, personally i am not a fan. it's not easy to work with or to get a good finish.
Dan the man
by Dan the man » Mon Apr 04, 2011 8:47 pm
Thistle one coat is a great solid undercoat plaster which doesnt crack, I wouldnt recommend using it as a finish plaster because it can be awkward to trowel up, I always use it for patching up but I always skim over it to finish the job.
It is currently Sun Nov 24, 2024 12:44 am
