Radiator valves
Freddy12
Radiator valves
by Freddy12 » Mon Apr 04, 2011 4:21 pm
Are lockshield valves and wheelhead valves constructed differently or are they the same but with a different platic cover?
Freddy
by htg engineer » Mon Apr 04, 2011 7:12 pm
The same but with different covers.
The lockshield valve is for balancing the system, then cannot be accidentally closed/opened
htg
Freddy12
by Freddy12 » Mon Apr 04, 2011 7:45 pm
As a follow-up, does it matter which valve is connected to the flow from the boiler?
Freddy
by htg engineer » Tue Apr 05, 2011 10:24 pm
You need to check manufacturers instructions for the valves you buy - the majority are Bi-Directional.
htg
