plastering blockwork in new conservatory
cheedmonds
by cheedmonds » Fri May 13, 2011 4:16 pm
Hi. I have recently had a new conservatory and to reduce cost at the time i had it left at where you can see the concrete blocks. Do these need to be boarded then skimmed or can plaster be directed directly to the blocks. If boarded would it need to be battoned then boarded or could they be dabbed. If plastered straight onto blocks what plaster would be best and what would be the best way to go about it.
Thanks for any help offered.
Che
plastering
by welsh brickie » Fri May 13, 2011 7:21 pm
You can use dry wall adhesive to stick the plasterboard directly onto the blockwork,then use a joint filler with tape to seal the gaps,sand when dry and paint.
Or same as above but use thistle board finish plaster to plaster over the plasterboard
chris_on_tour2002
by chris_on_tour2002 » Sat May 21, 2011 10:37 am
any of your listed options would work. you could go straight onto the blocks with an undercoat plaster such as bonding, browning or hardwall though on external walls a sand and cement render is preferred.
dry lining with battens or drywall adhesive are both fine as well and give the option of adding an insulation layer.
pays your money, takes your choice.
cheedmonds
by cheedmonds » Wed May 25, 2011 10:21 pm
thanks for the advice. greatly appreciated.
It is currently Wed Nov 27, 2024 3:55 pm
