ARISTON MICRO GENIUS 23 MFFI
Brows
by Brows » Thu Jun 21, 2007 5:54 pm
When trying to run hot water the flu light comes on and the water stays cold. If i move one of the joint 3 plastic pipes from the airflow switch and put my finger over one of the pipes it fires up. But as soon as I connect back to the airflow switich then flame goes out and water goes cold.
Could it be a faulty air switch or could it be a faulty flu has this only happens when it rains heavely.
wishiwascorgi
by wishiwascorgi » Sat Jun 23, 2007 11:40 pm
you can pick an air pressure switch up for about £20 so it would be worth trying first. If not then there could be a blockage in your flue. What type of flue is it?
toneyt
by toneyt » Tue Jun 26, 2007 6:35 pm
does the flue elbow have a venturi in it as thes can block
plumbers1
Micro Genus
by plumbers1 » Sat Jun 30, 2007 12:03 am
Venturi vent tube in flue needs checking for dust or blockage (blow through it and clean. If not this then air pressure switch about £25.00
