approved documenr part e sound resistance
totomorris
by totomorris » Mon Jul 25, 2011 11:59 pm
In secrion 4 it gives details for sound proofing for matterial use of change. The flooring details require a resilient layer of 60/100 kgm3 and 2 floating layers. min 8mm thick. Has anyone used this method of sound proofing and what products can be used for this system.
xavi99
by xavi99 » Sun Jul 31, 2011 9:25 am
Try Rockwool website, there have some good detail sheets there. There are also products such as acoustilay which is a matting laid on top of the floor. Might also be one called acoustimax.
However, any type of rubber matting will shrink when it's cold. It may also not be accepted by bg ctl
Also when laying matting on top you need to make sure that you insulated under all cpds, kitchen units etc,.
Of all the sound insulation problems I have encountered they have always been where the floors are upgraded. Ceiling upgrades seem alot more successful.
Good luck and take care with the detail.
Hth
99
It is currently Mon Jan 06, 2025 8:14 pm
