Bathroom coving
6 posts   •   Page 1 of 1
denboy09
Bathroom coving
by denboy09 » Wed Aug 03, 2011 7:16 pm
I want to put coving up in the bathroom. The walls are tiled right up to the celing. Will coving adhesive work to the flat ceramic tiles? :?
Brickworkz
by Brickworkz » Thu Aug 04, 2011 9:08 am
Not something I have ever tried personally but on first thoughts, due to the finish on the tiles, the adhesive would not bond.
If it were something that I would attempt, I would personally use the coving adhesive on the ceiling edge and try a bonding agent such as 'no nails' on the tiled edge.
If you secure some pin nails into the tile joints along the length of the coving so it can sit on, this will help it stop slipping as it sets and maybe try a test piece first to see the strength results.
coving
by welsh brickie » Thu Aug 04, 2011 12:10 pm
No it wont work, if its a plasterboard coving you will need to cut the tile first.then bed the coving onto the wall
denboy09
by denboy09 » Sat Aug 06, 2011 6:29 am
It would be almost impossible to cut the tiles. What if it put up wood batten against the tiles first then put the coving onto that. Would an adhesive "gripfill etc" work in a bathroom enviroment?
trand
by trand » Sun Aug 07, 2011 8:24 am
A grab adhesive will work on the tile edge smells a bit like evo-stick and that sticks anything, I've seen it were the tile comes off before you can get the stuff off, and a few small pins in the ceiling edge,
denboy09
by denboy09 » Sat Aug 13, 2011 2:37 pm
Thanks will try it
It is currently Tue Jan 14, 2025 1:22 am
