dry lining - how long?
mwsaunders
by mwsaunders » Thu Aug 11, 2011 8:59 pm
Well where to start, i am doing out the upstairs of our 3 bed house and as a keen diyer i am going to try and do as much of the work as i can.
My problem is untll the upstairs is boarded out the family is going to have to move out, and i only have limited time off work.
I know it is very subjective and obviously i wouldnt be able to do the job as quick as you guys would, but would you guys be able to give me a rough estimate of how long it would take to do?
Im doing out 3 rooms (bathroom is for a later date), all of which are square except for one wall with a chimney breast. In each room i plan to remove all of the old failing plaster on all walls back to the bricks and then dot and dab them.
The room dimensions are as follows:
1. 4.3m x 3m
2. 3m x 3m
3. 5.6 m x 4m
I know its impossible to be exact in any way, but can you give me any ideas how long you think it should take? I would class myself as competent, and will be putting a full days work as it were.
Or out of a matter of interest how long do you think it should take if i get someone in? As due to time constraints i might have to go down that route
drylining
by welsh brickie » Fri Aug 12, 2011 12:56 pm
it will take 1 day each room to dryline,its best if you get someone to mix for you.
mwsaunders
by mwsaunders » Sun Aug 14, 2011 5:50 am
Thanks for your reply :)
I have got told over on the other forum it would take about 5 - 7 days to do the job in total (that's without final skim btw), it has also been suggested i will need a skip or possibly 2 as well.
What does everyone think to this?
drylining
by welsh brickie » Sun Aug 14, 2011 4:09 pm
If you remove the plaster yourself and clear and prepair the room ready for drywall,Then to drywall 1 room it willl only take a day.
It is currently Wed Nov 27, 2024 3:57 pm
