connecting 5.8kw hob
Geoff1
by Geoff1 » Sat Jun 23, 2007 6:34 pm
I have just replaced a free standing cooker with a 7.5kw column oven using the existing 6mm cable and 45amp double pole cooker switch.
I now need to connect the 5.8kw hob which is situated 0.5 metre from the oven but i am not sure of the best way of doing this. I realize i need to have this work checked by an electrician. I would welcome some advice please.
BLAKEY1963
Re: connecting 5.8kw hob
by BLAKEY1963 » Sun Jun 24, 2007 7:17 pm
[quote="Geoff1"]I have just replaced a free standing cooker with a 7.5kw column oven using the existing 6mm cable and 45amp double pole cooker switch.
I now need to connect the 5.8kw hob which is situated 0.5 metre from the oven but i am not sure of the best way of doing this. I realize i need to have this work checked by an electrician. I would welcome some advice please.[/quote]
GEOFF1
DID A REPLY BUT NOT SURE IF I SENT IT ! TRY AGAIN.
ASSUME U HAVE EXISTING OVEN OF 7.5KW CONNECTED
TO A 6MM2 CABLE.
AND U HAVE A 5.8 KW HOB TO CONNECT UP.
IF U CONNECTED THIS UP TO THE SAME 6MM2 CABLE AND BOTH
APPLIANCES WERE USED AT FULL CAPACITY, ALTHOUGH WE USE
DIVERSCITY . THESE APPLIANCES USED FULLY WOULD OVER LOAD
THE CABLE AND THIS IS BAD PRACTISE. I HAVE SEEN IT DONE.
FOR SAFTEY I WOULD ADVISE THAT A NEW 6MM2 CIRCUIT BE INSTALLED, AND AS THIS IS NOTIFIABLE WORK U WOULD NEED TO GET A SPARKY IN .
BLAKEY1963
by sparx » Sun Jun 24, 2007 7:46 pm
Hi Geoff, as you may realise it's not good enough to get your work 'checked ' by an electrician it is illegal to do any electrical work in a kitchen yourself! so get a leckie in & let him work it out for you; it's much cheaper than a fine for breaking bldg. regs,
regards SPARX
Geoff1
by Geoff1 » Sun Jun 24, 2007 9:14 pm
thanks for the advice i will get an electrician in.[/quote]
It is currently Mon Jan 06, 2025 1:57 am
