Sagging Rafters
hels1976
Sagging Rafters
by hels1976 » Wed Jun 27, 2007 5:25 pm
I have just had a survey carried out on a property I intend to purchase and have been told that even though the roof was replaced 6 years ago the rafters are not properly supported and are sagging, if they are not looked at now then it will continue to worsen. He also mentioned purlins - what does this mean and what will it costs us? Should we be worried?
Bus Godden
Purlins
by Bus Godden » Fri Jun 29, 2007 3:11 pm
A 'Purlin' runs horizontally through the centre of a common raftered roof to give added strength to a relatively long span of timber, a lightweight roof may not have needed one.
Your roof was probably initially laid with moderately light slates, the new roof is likely to have been re-done with something heavier in comparison.
If access is possible the job of shoring it up should be fairly simple, and quite necessary.
Bus
It is currently Mon Nov 25, 2024 11:00 am
