strip or sand?
poula_jones
strip or sand?
by poula_jones » Thu Jun 28, 2007 8:14 am
Hi friend, new to this place.....so I may be posting this in wrong place. but I am thinking of refinishing my 1950's knotty pine kitchen cabinets. I do not know if I need to strip the original varnish off first than sand or can I just sand the cabinets using 120 paper?
[url=http://www.shuttermaster.co.uk/wooden-window-shutters/wooden-window-shutters.html]wooden window shutters[/url]
simaljon
RE: Strip or sand?
by simaljon » Thu Jun 28, 2007 1:59 pm
Hi and welcome.
I had the same dilemma with some 1930's pine doors that had been varnished so I imagine that kitchen cabs will similar. I tried sanding and found that the paper was getting clogged with the old varnish and I couldn't get into the detailed areas sufficently. Not to mention that my muscles took a pounding after several hours of vibrating with the sander!
In the end I plumped for chemical stripping and although it was a somewhat unpleasant job the results where much quicker and gave a better finish. If you can afford it take them to a professional stripper who will dip and strip them for you. Otherwise there are plenty of varnish removal kits etc around.
Today (five years on) I have a whole set of lovely waxed doors which look better and smell wonderful. They do need more care but it is worth it.
Good luck
Chivs
by Chivs » Mon Jul 02, 2007 11:23 am
Hi. Visit the projects page under paint stripping and you will find a very safe alternative to the so called nasty solvent based products out there.
It is currently Thu Nov 21, 2024 8:43 pm
