Surrey Flange
8 posts   •   Page 1 of 1
YD20010
Surrey Flange
by YD20010 » Sat Dec 10, 2011 5:03 pm
I wish to fit a surrey flange, but the new cylinder I have purchased has a 22 mm compression outlet. Can this be converted to take the surrey flnage or should I exchange the Gledhill cylider to one with a 1 inch outlet to suit the surrey flange fitting
plumbbob
Re: Surrey Flange
by plumbbob » Sat Dec 10, 2011 5:58 pm
The 22mm compression you mention is only a fitting screwed in to the 3/4" flange on the tank. This fitting can be removed and the Surrey flange fitted as a replacement. Be very careful when unscrewing as it is easy to kink the thin copper tank.
YD20010
Re: Surrey Flange
by YD20010 » Sun Dec 11, 2011 8:45 am
Thanks but I can see no but I can't see any sign of a flange/hex between the 22mm thread and where it enters the tank. Would I use a pair of pliers or grips to remove?
plumbbob
Re: Surrey Flange
by plumbbob » Sun Dec 11, 2011 12:24 pm
As a rule, the centre tap of a cylinder is a 3/4" bsp female thread and the 22mm compression is actually a separate 3/4" bsp male to 22mm compression coupling or elbow fitting. However, I can't see what you have so proceed with caution.
What does concern me is cylinders don't usually come with compression fittings attached as these are chosen by the installer to suit the installation. Can you post a picture?
If it is a standard fitting, grips or Stilsons will be required to remove it.
YD20010
Re: Surrey Flange
by YD20010 » Sun Dec 11, 2011 3:26 pm
Cylinder showing 22 mm compression fitting
Cylinder 011 resized.jpg (69.85 KiB) Viewed 4734 times
Top of cylinder showing 22 mm fitting and surrey flange
YD20010
Re: Surrey Flange
by YD20010 » Sun Dec 11, 2011 5:30 pm
Can this 22 mm fitting be removed and the ssurrey flange fitted?
plumbbob
Re: Surrey Flange
by plumbbob » Sun Dec 11, 2011 6:05 pm
Looking at it I would say not. Additional fittings on tank outlets are usually made of brass but that is copper. I have fitted plenty of tanks and probably Gledhill ones but have not come across this problem before. Contact your supplier or Gledhill in Blackpool themselves for advice.
YD20010
Re: Surrey Flange
by YD20010 » Sun Dec 11, 2011 6:18 pm
Hello Plumbbob
many thanks for your advice
It is currently Fri Jan 10, 2025 3:44 pm
