solid oak floor on to chipboard??
6 posts   •   Page 1 of 1
eddylyons
by eddylyons » Thu Jan 12, 2012 9:41 am
ive recently replaced all my floor boards down stairs with a 18mm chipboard floor, i have now found the solid wood that i like and have mixed responses on how to fit it.....been told not to nail as chipboard is weak.....not to glue coz floor will want to move naturally....so i thought of maybe just laying the floor over a underlay and not glueing at all would prob be best method.....obviously leaving the 12mm expansion gap around the edge of the wood. is this correct or should i throw a few nails in to stop the floor from having gaps appear over time?? thanks eddy
Re: solid oak floor on to chipboard??
by welsh brickie » Thu Jan 12, 2012 6:11 pm
no thats fine its called a floating floor,If you want no nail it down you need to screw-down 6mm ply to the existing chipboard.
eddylyons
by eddylyons » Thu Jan 12, 2012 10:19 pm
cheers brickie......what sort of underlay shout i use?? its only for sound purpose....?
by welsh brickie » Fri Jan 13, 2012 2:14 pm
there is an acoustic boarding you can buy, or a thin polystyrene 3mm.I think the board is 7mm but dont quote me on the thickness,you lay it on a 45 degree angle to the flooring.
eddylyons
by eddylyons » Tue Jan 24, 2012 10:53 pm
hi this weekend the floor is going to be laid, someone mentioned a dab of glue in the groove at both ends to keep them from spliting. what u reckon brickie?? sound ok??
by welsh brickie » Wed Jan 25, 2012 2:56 pm
yes
It is currently Fri Nov 22, 2024 6:53 am
