Insulating emd of terrace stone house
damianwills
by damianwills » Thu Feb 02, 2012 7:58 pm
hi was wondering how i go about insulating my end of terrace stone house as outside walls get very very cold and have mould that grows throughput the winter is thermal boards the answer to all outside walls ??? Please help
andy01
Re: Insulating emd of terrace stone house
by andy01 » Tue Mar 20, 2012 11:36 pm
i dont think i can anwere your question, but have you considered;
if you insulate teh external of your house
you may need planning due to the change of materials, ask the local planning department duty officer.
you will impeded teh natural ventilation you currently have through teh stone walls, so will need to ensure you remove moisture created by cooking, drying laundry, showers, breathing,
the roof may not project far enough.
the house will be bigger than next door and there will be a step in teh front elevation
the place where you stop the insulation externally will be where teh damp/mould begins
you dont want to bridge the dpc, hence you may get damp along teh bottom of all walls
if you insulate the inside of the house you will have
some of the probelms above
need to redecorate teh entire house
will have damp probelms at the floors where the insulation stops
the rooms will be smaller
maybe move house?
put the heating on higher
use a dehumidifier to remove the dampness, as mold grows due to a warm damp environment
It is currently Fri Nov 22, 2024 3:01 pm
