Lintel cost
twinturbo
Lintel cost
by twinturbo » Tue Jul 10, 2007 4:08 pm
I am lookng at knocking through from a kitchen into a utility space, a 3m Lintel would be required to support the outer wall.
It's a fairly standard 1930's 3 bed semi.
What sort of £££ should I be looking at for the demolishion and fitting of the lintel?
Ta
Rob
up4itsam
by up4itsam » Fri Jul 13, 2007 5:52 pm
usually between £300 - £400 if thats all you require plus the cost of the lintle which would probably be in the region of £100 although an rsj may be more more appropriate. It may be more if plastering and decorating is required as well
It is currently Sun Dec 22, 2024 12:00 pm
