Solar chips. Left loose or bedded in?
decam0
by decam0 » Wed Mar 14, 2007 8:29 am
We've just had our flat roof repaired. They've put on a layer of solar chips and left them loose. Is this correct or should they have been bedded into resin or some sort of adhesive?
thedoctor
by thedoctor » Fri Mar 16, 2007 1:02 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
tomcat1xxx
THE ANSWER FOR THIS IS NOT THERE UNDER THE PROJECTS.
by tomcat1xxx » Tue Oct 30, 2007 1:53 pm
doc
i couldnt find a answer for this under the project. it will be helpful if i can know what to do with the solar chiping.
regards
Ton
LCL
by LCL » Wed Oct 31, 2007 7:53 pm
decam0
Left loose should be fine. You can hot bed some into the top layer of felt but this is not necessary. If you live in a area with strong winds, you may need to redistribute the chippings every few years and clean the gutters out, otherwise the chippings will blow into the gutters, gradually fill them and collapse.
Hope this helps.
LCL
It is currently Mon Dec 02, 2024 2:53 pm
