Roof Beams
A Booker
Roof Beams
by A Booker » Wed Jul 11, 2007 3:29 pm
Hello, I am renovating a 1930s bungalow and the beams which support the main roof structure have been removed. These are the beams which run from the centre of the loft floor at about 45 degrees to support the cross beams on each side of the roof. I know that this house originally had these beams and I want to replace them so that the roof is properly supported. Could you please tell me what size of wood I should use and/or what size and type of wood the original beams would have been on this age of house. Thanks
Kain
by Kain » Thu Jul 26, 2007 10:32 pm
4"x2" sawn timber is fine for this job. Make sure the timber is dry before you install. Do not fix the struts to just a single joist below the purlin. Run a peice of timber parallel with the purlin to enable struts to sit on. This will spread the load better.
Hope this helps.
It is currently Mon Dec 23, 2024 12:03 am
