painting over varnished wood
7 posts   •   Page 1 of 1
Smokey
by Smokey » Thu Mar 15, 2007 10:25 am
Can anyone tell me the best way to paint over varnished wood paneling?
I want to apply vinel mat paint for the finnish. Should i just use suger soap and then paint over I doon't really want to do a lot of rubbing down.
mikester
by mikester » Thu Mar 15, 2007 7:44 pm
It all depends what state the existing varnish is in. If its okay with no cracks or flaking then you should get away with just a light rub over with a 240grit sand paper just to give the paint a key and a wipe over with white spirit to remove the dust, other wise its a case either chemical or manual removing of the varnish.
When you do paint be sure to use an oil based under coat and an oil based vinyl matt top coat.
thedoctor
by thedoctor » Fri Mar 16, 2007 12:54 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
Smokey
by Smokey » Sat Mar 17, 2007 3:00 pm
Thanks to u both. I didn't think that u could get oil-based vinyl matt - you learn something everyday :) :D BTW the varnish is in good condition so i might just go that route.
tizfreespirit
by tizfreespirit » Thu May 10, 2007 10:10 am
Hi there I noted on your question, you said you didnt realise that you could get a vynl matt that was oil based, I cant seem to find one so I wondered if you did if so what make where etc. Regards trish
Smokey
by Smokey » Sat May 12, 2007 10:45 am
I think they were tslking about Eggshell oil based paint:
Links removed as they could be advertising. Advertisers should go to our page www.diydoctor.org.uk/trade.htm
hope it helps
Smokey
by Smokey » Sat May 12, 2007 10:48 am
[quote="tizfreespirit"]Hi there I noted on your question, you said you didnt realise that you could get a vynl matt that was oil based, I cant seem to find one so I wondered if you did if so what make where etc. Regards trish[/quote]
I think they were talking about eggshell paint:
Link removed as it could be advertising. Advertisers should go to www.diydoctor.org.uk/trade.htm
hope this helps
It is currently Wed Feb 05, 2025 6:59 pm
