Concrete a wall
graham_woodwarduk
Concrete a wall
by graham_woodwarduk » Thu May 17, 2012 11:10 am
I recently had a new damp proof applied to an internal wall and in order to have the damp proof done I had to remove the old plaster/concrete down to the brick work.
I plan to re-concrete this at the weekend and was hoping for some useful tips.
What kind of mix ratio should I use?
The engineer who done the damp proofing suggested using a 4:1 mix with a water proofer as well?
How do I stop cracks appearing?
Do I need to do anything to the exposed brick work prior to adding the concrete? (e.g. wet the walls?)
Thanks for any tips,
Graham
Super chip
Re: Concrete a wall
by Super chip » Fri Jun 08, 2012 10:19 pm
Pva the area first and then "dub out" the wall (fill any deep voids e.g mortar joins, broken bricks). Allow to dry and then do a full coat of render adding the waterproofer. All this should be done with the reccommended 4-1 mix, once semi dry key the surface. Then add a top coat of render once dry, but make this coat a 5-1 mix to avoid cracking.
It is currently Fri Nov 15, 2024 10:06 am
