shower pump
speedwing
shower pump
by speedwing » Wed Jul 25, 2007 9:06 am
I would like to install a twin impeller shower pump. The cold water comes from a tank in the loft and the hot water comes from a hot water tank just outside the upstairs bathroom, ie it is a positive head shower pump situation.
Can I install a twin impeller shower pump underneath my bath just before the hot and cold water enter bath/shower mixer tap?
Your quick response would be appreciated.
wingleburtbenglebink
by wingleburtbenglebink » Wed Jul 25, 2007 5:42 pm
Yes, but bear in mind that a bathroom is a special location from an electrical point of view. If a tool is needed to access the pump I think it counts as outside of zone 2 but check this. Your switch gear will have to be ipx4 if it is located in the bathroom, so you will need to consider this too.
It is currently Sat Nov 23, 2024 1:14 pm
