lights permanently on ??
andy29764
by andy29764 » Wed Jul 25, 2007 7:06 pm
have just changed a light fitting and now the lights are permanently on when switching, what is wrong ???
both incoming earths are together and wired to fitting.
both red live wires are looped together in a connection block.
one neutral is wired to the neutral side of light.
other neutral with red sleeve is wired to live side of fitting.
at switch, red live is common, and neutral is wired to L1
by sparx » Thu Jul 26, 2007 3:41 pm
Hi andy, did you get it wrong first time & short sw.? It happens! if so disconnect sw [1 wire] does light go off? if so replace sw. regards
SPARX
It is currently Sun Jan 12, 2025 11:29 pm
