Concrete or timber first floor
neilfairclough
by neilfairclough » Mon Aug 13, 2012 5:42 pm
I am renovating a barn in France and need to install a first floor over a 90 sqm area. I will build a load bearing wall to split the area into 2 (leaving spans of about 5m) and tie in the built floor to the existing stone walls. I am keen to keep the floor thickness to the minimum consistent with carrying the necessary (domestic) load, incorporating water based UFH in the first floor and necessary insulation. The ground floor space will become an independent apartment with the main house above. Options for the floor construction include concrete beam and block or timber. I would be very interested in views on the benefits of both options to include sound, fire and thermal insulation, ease of building and cost. Any guidance on suitable references would also be gratefully received.
Re: Concrete or timber first floor
by welsh brickie » Sat Aug 18, 2012 8:43 pm
for me I would use timber,but concrete is just as good,Cost wise timber is cheaper.ForElectricians & plumbers timber is easier so labour costs are minimized.But if your planning to tile the floor then concrete is better
neilfairclough
by neilfairclough » Thu Sep 06, 2012 10:00 am
Thank you for your comments. Structural engineer coming on Saturday to calculate loads to make sure I don't end up falling into neighbour's (downstairs) apartment. Given intention to ensure best possible acoustic insulation between house and apartment we will probably go with concrete 'plancher collaboration' (spelling?) as this is thinner, and lighter weight, than beam and block. I am doing as much of electrics and plumbing as is sensible so will have to live with the difficulties.
It is currently Tue Jan 07, 2025 1:02 am
