problem with upstairs toilet flushing
ruangwilai
by ruangwilai » Sun Aug 26, 2012 12:38 pm
When the upstairs toilet flushes, it takes forever to refil, but if you switch on the cold water tap full on, and leave it running for a minute,then switch it off, you can hear the water refilling the cistern in the toilet. This seems to be the only way to speed it up. Has anyone any ideas on how to sort out this problem and get it working as it should do.
The shower in the bathroom works ok but the water pressure is not very strong, could the toilet problem have anything to do with the water pressure not being strong enough? If so how can this be rectified.
Re: problem with upstairs toilet flushing
by htg engineer » Mon Aug 27, 2012 10:04 pm
If you're having problems with the shower and the toilet, then yes it does point to the mains water pressure, make sure all valves are fully open and see if there's an unnecessary restrictions i.e non return valves etc.
It is currently Fri Jan 10, 2025 6:46 am
