Gas fire not giving sufficient heat
john9159
by john9159 » Sat Dec 15, 2012 10:30 pm
I had a Valor Black Beauty (Model 349) installed last winter. I noticed then that the heat output wasn’t all that great but left things as they were. This year I notice the room temperature barely exceeds 19°C and am concerned that something has not been done according to the installation manual. The previous gas fire gave a good heat even though the efficiency was only about 50%.
The screw within the restrictor elbow is fully open.
Parameters of the fire are:
Max output heat 4Kw
Min output heat 1Kw
Efficiency 74% (gross)
Can someone please help.
proptech
Re: Gas fire not giving sufficient heat
by proptech » Sun Dec 16, 2012 10:42 am
I can only suggest that you get a registered Gas Safe engineer to check it out. If you have some doubt as to the installation, there may be a safety concern.
by htg engineer » Thu Dec 27, 2012 10:03 pm
The more modern gas fires are not as good as the old radiant type fires. A lot of the heat is lost up the flue, they're great for decorative effect but not for heating a room effectively.
soulman
by soulman » Fri Mar 22, 2013 8:29 am
4kw is'nt that high, if its 74% efficient that equates to 3kw.
A lot of other fires convecter box and radiant fire are higher, usually 6.9kw to keep under the threshold for requiring an air vent. So even at 50% efficiency you will get 3.5kw out. There is no adjustment to gas consumption on modern fires, so unless the pipe work is under sized it should be correct.
It is currently Fri Nov 22, 2024 6:34 am
