replacing halogen with led bulbs?
2yellows
by 2yellows » Wed Jan 09, 2013 7:43 pm
I currently have mr16 halogen lamps and bulbs in the kitchen and gu10's in the bathroom.
Can I just replace the bulbs for led version?
not sure if the holders or wiring need to be changed.
2yellows
kbrownie
Re: replacing halogen with led bulbs?
by kbrownie » Thu Jan 10, 2013 9:13 pm
You should be okay changing the GU10s.
The MR16 require transformers,you will need to check these are compatible for LED lamps.
2yellows
by 2yellows » Thu Jan 10, 2013 9:46 pm
Thanks Brownie
by stoneyboy » Sat Jan 12, 2013 1:49 pm
2yellows, In my experience LED lamps are pants. Try one before you replace them all.
It is currently Fri Nov 15, 2024 4:41 am
