My basin hole is too small ??????
bunny1072
by bunny1072 » Tue May 07, 2013 12:22 pm
I'm trying to fit a mono mixer tap to our cloakroom style basin but the tap hole is too small for both the bracket and connecter hoses to go through . Is there another way I can fit it or do i get a new basin???
plumbbob
Re: My basin hole is too small ??????
by plumbbob » Tue May 07, 2013 8:27 pm
Sometimes you have to connect the pipes after fitting the tap loosely to the basin instead of trying to feed everything through the hole in the basin.
Having said that, some foreign manufactured basins won't take a standard UK tap. I have come across that problem before.
bunny1072
by bunny1072 » Wed May 08, 2013 10:29 am
Thanks Plumbbob but yes tried that , cannot fit the bracket bolts and hoses through .
plumbbob
by plumbbob » Wed May 08, 2013 8:44 pm
A normal basin mixer tap hole is in the region of 35mm in diameter. If the hole in your basin is significantly smaller, then the basin is not a standard UK size. If it is 35mm, then maybe the tap is a non standard size.
AFAIK, there is only one standard size in the UK.
It is currently Mon Jan 27, 2025 12:56 am
