No hot water from basin mixer tap
pvuv
by pvuv » Sat May 18, 2013 10:26 am
hello.
I had installed a waterfall mixer tap in my bathroom and for the first year all was working well with good pressure
http://s.taps4less.com/PI/T-AQ4R.jpg
depending on the lever position (left for hot and right for cold) i was able to mix the water but now positioning that lever has no effect and i am always getting cold water.
this can happen any time of day and could last from mins to hours.
is my tap faulty and do i need to replace any part in it
many thanks for your help.
(my knowledge on tap mixer / tap parts = 0)
neilorrick
Re: Help with Basin Mixer !!! NO hot water.
by neilorrick » Wed May 29, 2013 7:23 am
I am new in this forum and in my opinion the problem will be in the mixer you just open the mixer may be a hot water valve jammed and water is not passing from there. Might be you have to replace the valve.
It is currently Tue Nov 26, 2024 4:36 pm
