Grout And Cement Residue On Enamel Bath
Jess1485
by Jess1485 » Fri Oct 04, 2013 12:26 pm
My bath has clearly been used, when the bathroom was being refurbed, as a place to hold grout or mix some sort of concrete. The result is a rough discoloured surface.
I would be grateful for any advice on how to remove this.
Jess1485
proptech
Re: Grout And Cement Residue On Enamel Bath
by proptech » Fri Oct 04, 2013 8:24 pm
Hi Jess1485
I'm going to suggest the use of a normal lime scale remover of the type in any supermarket - Viakal, Limelite, or similar. Just spray on and leave to work. Any product that works with scale should be able to soften cement to some degree, and must be worth a try. Another product that may work is distilled vinegar.
There are more powerful products out there, but their use may involve some danger.
Let's know how you get on.
Jess1485
by Jess1485 » Sat Oct 19, 2013 1:02 pm
Thanks for the great advice. Viakal worked a treat and the bath is fine. I will not need to get it re-enamelled after all.
Regards.
Jess1485
It is currently Mon Nov 25, 2024 6:54 pm
