Propagating Box and Choice of Thermostat
senojbdet
by senojbdet » Wed May 28, 2014 12:00 pm
I have made a Propagating Box for my Pelargonium cuttings.
The bottom heat is provided by 2 x 11 Watt bulbs.
I need to control the heat at 21 degrees 'C' so I plan to use a rod type Thermostat that will fit just below the tray holding the cuttings.
It is a ' BACKER BACKERSAFE STANDARD THERMOSTAT ROD STAT 7" ' which I believe is for controlling the heat in domestic hot water boilers.
Will this be OK?
proptech
Re: Propagating Box and Choice of Thermostat
by proptech » Wed May 28, 2014 6:50 pm
In a word, no. This is an immersion heater thermostat, and will not control at such a low temperature. Probably the lowest it would go to would be 40 degrees.
I have to say that I'm a little concerned with the electrical safety of this project. Components like this thermostat are designed to be in a fully enclosed appliance housing, and would only be considered safe if used as intended.
senojbdet
by senojbdet » Wed May 28, 2014 7:38 pm
Many thanks for your so quick reply!
I chose this Thermostat because the control range is 15 to 65 degrees 'C'
However, I will heed your advice and see what else I can get.
If you have any ideas I would be most grateful.
The box will be used in the house and will NOT be in any contact with water.
Once again, many thanks.
It is currently Tue Jan 14, 2025 11:14 pm
