Re-painting Bedroom Advice - Sand all Walls or Sand Only Flaking Areas?
jimboss007
by jimboss007 » Sat Jul 05, 2014 5:32 pm
We have recently moved into a new house and are about to start decorating one of the bedrooms. At present, the finish on the walls is terrible (peeling paint, lots of screw holes that need filling etc). We have stripped some of the peeling paint off the walls already (there appears to be several coats of paint previously applied). Is it best to scape all the walls back to the plaster and then sand and prime everything before re-painting or is it ok to scrape the peeling areas only then sand down to blend in before priming the areas where the plaster is exposed before painting the whole lot? We are new to all this so any advice would be greatly appreciated.
thedoctor
Re: Re-painting Bedroom Advice - Sand all Walls or Sand Only Flaking Areas?
by thedoctor » Fri Jul 25, 2014 12:50 pm
It really depends on the quality of finish you require. Stripping some paint of and leaving some on usually leaves a raised edge and this is usually still visible no matter how much sanding you do. For a perfect finish it is usually better to get back to a good base and start again. Stripping paint is a wholelot easier with the new solvent free product we have just found called Home Strip. You can see it here,there is a video you can watch next to the product also. Click on the red video box
https://www.diydoctor.org.uk/DIY-superst ... litre.html
It is currently Wed Nov 27, 2024 6:27 am
