Position of flume
roton600
Position of flume
by roton600 » Fri Aug 03, 2007 10:25 pm
Hi need some advice, my neighbour has just had his boiler changed to a condensing one, it’s a Worcester Greenstar 15RI. I am mid terrace and the plume is about 200mm from our boundary on his side and about 2.2m from the ground. Does this comply to building regs? Don’t want to start complaining if it conforms.
GeckoGas
by GeckoGas » Sat Aug 04, 2007 8:01 pm
Hi; the GreenStar 15Ri has to be a minimum of 300mm from an adjacent boundary or 600mm if facing the boundary.
In all cases, the regs state that care should always be given to the pluming effect of a condensing appliance and where needed, a plume management kit should be fitted.
roton600
by roton600 » Sun Aug 05, 2007 3:44 pm
Hi, thanks for that i will talk to the guy, if he does not fix who do i complain to?
muzza
by muzza » Sun Aug 12, 2007 1:09 pm
local building control dept
ollie83
by ollie83 » Mon Oct 15, 2007 10:44 pm
its easy to fix this problem as worcester do a plume management kit wich can direct the plume away from your property.
It is currently Fri Nov 22, 2024 2:41 pm
