Big heavy wall unit - what fixings are best to use?
Charlie7000
by Charlie7000 » Sat Sep 06, 2014 9:32 am
Hello. I wonder if any of you nice experts can advise me on the best fixings for this pine wall unit/dresser/plate rack please. It is large and heavy, solid thick pine and is 33" wide 31" tall and 9" deep. It has four brass type attachments with holes in - two near the top and two about a third down. I bought it second hand so no fixings with it.
It is going on a stone, plastered wall, and will be holding a lot of weight with crockery etc and even some books maybe. Wish I had thought about this before getting it! We are a bit nervous about fixing it up.
I have bought 3 sets of fixings from local diy shop and wondered which, if any, would be the best to use.
Here are some pics - apologies for blur in some:
Forge Fix easy-fix frame/batten fixing M10 x 115 "a quick and simple fixing for most applications"
Forge fix universal plug and screw.  Screw size 6 x 80, plug M10
Forgefix masonry anchor, loose bolt type M8 x 25
Metal bracket with hole
Plate rack/dresser
Plate rack/dresser
Re: Big heavy wall unit - what fixings are best to use?
by welsh brickie » Sat Sep 06, 2014 4:09 pm
try thunderbolt fixings no rawplugs required, or stardrive frame fixings
It is currently Mon Dec 23, 2024 11:00 am
