Masonry Partitions on Timber Floorboards - How to Insulate Underneath Floorboards?
simonL
by simonL » Mon Sep 15, 2014 4:17 pm
I have recently bought a 1930's semi and want to insulate the GF. I have discovered the masonry non-loading bearing partitions are built off the floorboards. They are NOT located directly over floor joists which run in the same direction.
How do I get these floor boards out to allow access underneath to insulate without having to knock the wall down?
Mad110
Re: Masonry Partitions on Timber Floorboards - How to Insulate Underneath Floorboards?
by Mad110 » Wed Nov 26, 2014 10:40 pm
Is there enough space under the gf to cut an access hatch and put in rigid foam insulation from below?
It is currently Mon Nov 25, 2024 3:34 am
