Bath Hot Water not Very hot but Sink Taps High Temperature?
Matthangzhou
by Matthangzhou » Mon Mar 02, 2015 9:13 am
Hi everyone. I have some limited diy knowledge and like to get stuck in when I can however I'm not sure if this is a big problem or not.
Basically the hot water from our bath tap isn't very hot. It's warm enough for a bath (just) but the temperature from the sink and kitchen sink is much hotter (scalding really).
Any idea ls on how to increase the bath temperature?
Thanks in advance
proptech
Re: Bath Hot Water not Very hot but Sink Taps High Temperature?
by proptech » Mon Mar 02, 2015 11:08 am
You'll have to let us know what supplies your hot water, what sort of system do you have ?
Matthangzhou
by Matthangzhou » Mon Mar 02, 2015 7:50 pm
proptech wrote:Hi
It's a Worcester combi boiler located in the kitchen.
Matthangzhou
by Matthangzhou » Wed Mar 04, 2015 8:15 pm
No ideas?
proptech
by proptech » Thu Mar 05, 2015 7:34 pm
Sounds like an issue with volume of flow. If there is a greater flow rate at the bath, the water will be cooler. A restricted flow means hotter water.
It might be a good idea to have a word with your engineer/installer. A few adjustments may solve the problem.
It is currently Sun Jan 12, 2025 1:41 am
