Nexus 8 Alarm System That has Never Worked Correctly - How to Setup and get Working?
take5
by take5 » Tue Mar 31, 2015 2:17 pm
I have a Nexus 8 alarm system that's never worked properly and I would like to getting working.
How do I go about getting this alarm system working? I have no manuals etc. Can I get paper work showing me how to set up this alarm system.
All suggestions gratefully received.
Re: Nexus 8 Alarm System That has Never Worked Correctly - How to Setup and get Working?
by ericmark » Wed Apr 01, 2015 3:46 pm
To publish manuals that all can read would mean those wanting to break in could also read them.
We has this problem with the early Range Rover factory fitted alarm when thefts found they could open bonnet plug in a box of tricks which allowed them to unlock doors and switch on the ignition making it easier rather than harder to steel the car.
The house alarm to be monitored has to be maintained by members of an overseeing organisation which means any alarm maintained by the home owner has a very limited function.
Clearly it can be set to ring a bell outside if by-laws permit many areas only permitted to flash a light. Again this is a problem for DIY as one often does not know what is permitted in your area.
Unfortunately Nexus 8 is also the name of a tablet so hard to find info. It does seem there are key pads and phone diallers which can be added so it would seem it's reasonable quality. And it seems it is British so likely alarm installers will take it over.
But this having to use monitoring stations really means any DIY with alarms is out.
take5
by take5 » Thu Apr 02, 2015 10:20 am
I found it! (on google) download them
I also emailed lynteck who sent me copys of bother manuals
It is currently Mon Jan 13, 2025 4:51 pm
