6x6 as Ridgeboard for Shed Construction With Pitched Roof?
kragen2179
by kragen2179 » Sun May 03, 2015 5:52 pm
So I am building a shed 16'x12' with a 12/12 pitch roof.
I intend to use 2x6 for the rafters, but am curious about the ridge board, most sites I have found suggest to use 2x6 also. Although I would be inclined to use 2x8 so that the entire face of the rafters end is touching.
HOWEVER since I am going for a 12/12 pitch, the apex of the roof will have a 90° angle. If I use a 6x6 beam instead of a board, I would not have to cut the ends of the rafters to match the 45° angle required to fit the rafters.
Is this a viable alternative or should I stick with using a board?
What would the reasons for not doing it be?
michaelbailey
Re: 6x6 as Ridgeboard for Shed Construction With Pitched Roof?
by michaelbailey » Thu May 14, 2015 1:51 pm
make your own trusses where the cut joists meet use 25mm ply cleats either side of the joists . you can also fit in some tie beams at ceiling height this will stop roof spread insert extra ties at mid span to prevent sagging
It is currently Sun Dec 22, 2024 3:36 pm
