Removing Wall with 2 Sockets in and Repositioning Them?
PickledSquirrel
by PickledSquirrel » Fri Jun 19, 2015 8:17 am
We have a large fitted wardrobe in the master room which needs to be removed, but fitted to the wardrobe behind the bed area is a stud wall which has 2 sockets.
How can I remove the wall safely and move the sockets to the actual wall 6" behind it?
Thanks,
BLAKEY1963
Re: Removing Wall with 2 Sockets in and Repositioning Them?
by BLAKEY1963 » Mon Jul 27, 2015 1:37 pm
Pickeldsquirrel
after safe isolation of electricity supply at your mains board , supply turned off , your cables can be inspected to assess how they are connected to wall material, cable capping, conduit, clipped direct. do you have enough slack to connect up to new postion. a registered electrician in your area can test and inspect for you and issue any relevant certs .
It is currently Mon Jan 13, 2025 9:43 am
