Changing a bathroom light
CDJEMERY
by CDJEMERY » Tue Aug 07, 2007 9:08 pm
I have purchased a new bathroom light and went to change the one currently in use - which appears quite old.
When disconnecting the old fitting I noticed that the wires would not connect into the new fitting.
There appears to be some kind of "plug" that I need to connect to the existing wires to be able to connect into the new fitting.
Is this correct or is there something else I need to do
BLAKEY1963
Re: Changing a bathroom light
by BLAKEY1963 » Tue Aug 07, 2007 10:03 pm
[quote="CDJEMERY"]I have purchased a new bathroom light and went to change the one currently in use - which appears quite old.
Thanks[/quote]
CDJEMERY
CAN ONLY ASSUME THAT YOUR SET UP IS A PLUG IN TERMINAL
BLOCK .
YOUR TWO WIRES GOING 2 EXISTING FITTING SHOULD BE
RED / BLACK RED TAG = LIVE
BLACK = NEUTRAL
BARE COPPER WIRE WITH GREEN SLEEVING = EARTH.
YOUR LIVE FROM ABOVE SHOULD GO TO BROWN OF FITTING
YOUR NEUTRAL FROM ABOVE SHOULD GO TO BLUE OF FITTING. ( ISOLATE TO REMOVE BLOCK FIRST AFTER WORKING OUT WIRES)
BLAKEY1963
It is currently Mon Jan 13, 2025 2:28 am
