Flexible Tap Connectors leaking
lsuui
by lsuui » Tue Aug 07, 2007 10:19 pm
After connecting original pipe work to new flexible pipes, leading to a bathroom sink tap, the water squirts out between the flexible tap connector nut and the flexible tap connector pipe itself. I've tightened the nuts and put ptfe tape on the thread but the flexible pipe still wobbles in the nut, which is letting water past the rubber washer and out.
Any clues?
james
The type of flexible tap connecot can be seen here
http://www.screwfix.com/app/sfd/cat/pro ... 2&id=27936
by htg engineer » Wed Aug 08, 2007 9:38 pm
New flexible connector required, or copper pipe put in its place. there's no way to repair these hoses if you lose the watertight seal, not that I know of anyway. Shouldn't cost much.
Hope this helps
johnb
by johnb » Sun Aug 12, 2007 12:05 am
hi isuui the flexi you show does not have rubber washer it is designed for 15mm copper tube with olive it is a compression fitting and does not need ptfe tape are you sure this the fitting you used from screwfix. all the best john
waztastic
by waztastic » Sun Aug 12, 2007 8:54 pm
you can get liners to put inside the end of the plastic pipe before tightening any fixings on
It is currently Fri Nov 22, 2024 11:18 am
