Mitre Saw for Cutting Bricks With a Diamond Blade
Dwidge
by Dwidge » Sun Jul 19, 2015 11:14 am
Can anyone recommend a saw which will take a diamond blade and be suitable for cutting and mitring fire bricks? Needs to cut about 3 inches deep.
DIYDoctor2
Re: Mitre Saw for Cutting Bricks With a Diamond Blade
by DIYDoctor2 » Mon Sep 07, 2015 12:31 pm
You will need to use a 9 inch (230mm) angle grinder with your diamond blade, such as these ones here: https://www.diydoctor.org.uk/DIY-superst ... -disc.html
The best way to go is construct a jig for your grinder from timber and set it at the exact angle you need. You can buy angle grinder stands but I’m not sure they do stands for mitreing, although you could buy one and adapt it, such as this one: http://www.amazon.co.uk/Wolfcraft-50190 ... B000P3DX6K
It is possible to buy concrete/block mitre saws but they are hugely expensive.
Hope this helps
hellobob
by hellobob » Sat Jul 15, 2017 5:43 pm
Hi was having problems cutting bricks for my bay window 45° angles. I went to facing-bricks.co.uk and they sorted it. collected bricks from my house, cut and bonded them and delivered them back. a lot easier than doing it myself.
It is currently Sun Feb 02, 2025 8:53 am
