No Hot Water From Nearest Hot Tap to old Vaillant Boiler?
Carnegie
by Carnegie » Wed Jul 22, 2015 5:40 pm
I have an old Vaillant combi boiler which is/was working fine. When I turn on kitchen hot tap (nearest tape to the boiler) the boiler does not fire but when I turn on the bathroom basin hot tap it fires and produces hot water. If I then turn on kitchen tap, hot water also comes out. I recently had the diverter valve diaphram replaced following similar problem. Any ideas
DIYDoctor2
Re: No Hot Water From Nearest Hot Tap to old Vaillant Boiler?
by DIYDoctor2 » Mon Sep 07, 2015 10:35 am
This sounds like you will need to check the installation of the diverter valve again as it may not be diverting correctly
Hope this helps
It is currently Sun Feb 02, 2025 8:49 am
