Switched Water on and Constant Flow Coming from Overflow Pipe with Water Tank Empty
broonie30
by broonie30 » Mon Sep 14, 2015 10:48 pm
I've just moved into a repossessed house and have just switched the water on. As soon as I did this water is flowing constantly out the overflow pipe.
I've been up to the loft where the tank is empty and water is filling into the tank though it just seems to be coming straight back out the overflow, and the water tank drains down.
Sure there must be a simple fix. Any advice would be most welcome.
Thank you
diydoctor6
Re: Switched Water on and Constant Flow Coming from Overflow Pipe with Water Tank Empty
by diydoctor6 » Tue Dec 22, 2015 2:08 pm
Where does the over flow enter your tank?
It sounds like at the bottom for it to overflow before it fills up?
It is currently Sat Nov 16, 2024 8:22 pm
