by tileclipproman »
Sat Dec 12, 2015 12:55 pm
All those clips have a small hole in them if I am seeing right,if that is the case you want to use the top 3 fixings to fix from.
best way is to make a template say of the top 3 fixing clips then tape the template to the wall.The most commen picture fixings are the nail & hook type.
wall needs to be sound and you just hammer them in.If plasterboard walls then you will need dry wall fixings.
