Is Cutting Joists to Extend Loft Hatch Extension Feasible?
ss002d6252
by ss002d6252 » Sat Jan 02, 2016 4:33 pm
The loft hatch I have the moment is just between 2 joists (all 5" x 2") and ideally I need to extend it across to the next joist. Is it it feasible to cut this joist
The joist which will need be cut is the middle joist in the attic ( I can't cut the joist the other way as it has pipework on it). Is it safe to cut this joist and extend the hatch ?
Red is the middle joist in the attic. The yellow square is the approximate area to which I want to extend the hatch.
Re: Is Cutting Joists to Extend Loft Hatch Extension Feasible?
by welsh brickie » Sun Jan 03, 2016 10:27 am
you cant just cut it out, without supporting the joist otherwise its making it structurally unsound.
you will need to support it using joist hangers, and fitting a trimmer joist.
its best if you get someone in to do it for you
ss002d6252
by ss002d6252 » Sun Jan 03, 2016 11:31 am
welsh brickie wrote:you cant just cut it out, without supporting the joist otherwise its making it structurally unsound.
I've got no problem with being able to actually cut and insert the new sections of joist euc
The main concern I had was with the particular joist going right under the centre post - providing that in itself isn't an issue then I'll be Ok.
Craig
It is currently Sun Dec 22, 2024 1:19 pm
