Filling large and deep hole in a brick wall to hang curtain holders
7 posts   •   Page 1 of 1
Pino
by Pino » Sat Jan 23, 2016 9:20 am
Hi All,
I have a large hole 10 cm wide, 10 cm high and 5 cm deep in my brick wall and I would like to know what is the best way to fill it. Once it is filled I would like to be able to drill holes in it so that I can hang curtain holders.
Re: Filling large and deep hole in a brick wall to hang curtain holders
by welsh brickie » Sun Jan 24, 2016 7:19 pm
Mix a P.V.A solution and apply it on the area, then mix some dry wall adhesive and fill the holes, the mixture should be like thick cream, over fill the holes slightly and sand back when set 24hrs later
Pino
by Pino » Sun Jan 24, 2016 10:37 pm
Thanks but since the hole is quite deep if I fill only with wall adhesive would I be able to drill and hang curtain on the filled hole?
by welsh brickie » Sat Feb 20, 2016 9:10 pm
yes
Pino
by Pino » Sun Feb 21, 2016 8:58 am
Could you please let me know what wall adhesive should I use?
melving.crane
by melving.crane » Wed Mar 23, 2016 5:09 am
Pino, I think you should use cement plaster on the deep holes. Make cement mixture liquid type and paste the liquid cement into the hole. Hopefully it'll be add nicely, so that you can later make hole to hang curtain holders.
Pino
by Pino » Thu Mar 31, 2016 9:08 am
Hi Melving,
could you advise what product to use which I can easily find in one of the DIY stores?
Emanuele
It is currently Fri Nov 22, 2024 7:25 am
