I am currently doing our bathroom. I have had to take off the window sill which has revealed a thin 25mm of insulation in the cavity in some areas (I am quite surprised there was any!).
I was going to add some more where I can, there is cement sticking out the wall so I can't get much in. I was also going to use foam around the window frame as there is none, and I can feel a draught coming through.
Is there anything I can do to make it better? What would you do?
Thank you!
