uPVC Windows With no Lock in Property I'm About to Move to
alison_hay_18
by alison_hay_18 » Mon Mar 07, 2016 3:59 pm
Hi! I'm about to move into a new property next month and the upstairs uPVC windows don't appear to lock unless I am missing a trick. There is no lock for a key - is there any other way to lock other than with a key? Am I missing something?? When it is in the vertical position it doesn't open, move 90 degrees or 180, it opens - this isn't ideal as I have children and don't really want them falling out the upstairs bedroom windows!
The windows were installed when the house was built 2003 by Persimmon homes. Interior window code is: TOTAL 04 2003 Complies BS5713 - which doesn't really help as it just seems to take me to the british standard codes. A panel does in the interior says GU Feroc but they might just have supplied the part. Nothing on the handle tells me that this locks or if it does, HOW it locks in absence of a key?
Any ideas?? Many thanks Alison
Fred c
Re: uPVC Windows With no Lock in Property I'm About to Move to
by Fred c » Mon Mar 07, 2016 9:35 pm
Hi Alison these windows are meant to be used as escape in the event of fire this is why they can not be locked with a key. You can however fit a childproof device to windows to protect your children. These devices usually available from window companies.
alison_hay_18
by alison_hay_18 » Tue Mar 08, 2016 11:17 am
Dear Fred, Great! Thanks I will look into these, just didn't know if I was missing a trick! Alison
harvsey69
by harvsey69 » Fri May 06, 2016 6:02 am
Hi this may be a little late but it indeed does sound like they are fire escape handles which at first glance look like there is no key hole but most manufacturers put a black grommet in the original hole where the key would have fitted which can be removed with something sharp then exposing the key whole hope this may be of some help
It is currently Thu Dec 05, 2024 2:24 am
