mechanical protection?
tsb
by tsb » Mon Aug 13, 2007 9:38 pm
Could plastic capping be classed as 'mechanical protection' when using it to cover cable.
fabriqnumba
by fabriqnumba » Mon Aug 13, 2007 9:58 pm
in short no it cant. mechanical protection is steel conduit or bury said cable 50mm deep from surface of wall.
by sparx » Mon Aug 13, 2007 11:19 pm
hi, No, it's only function is to stop plasterers damaging cable!!!
Mechanical protection must be metel, & if more than say a plate across a single joist needs to be earthed as well, regards SPARX
tsb
by tsb » Mon Aug 13, 2007 11:49 pm
Thanks sparx.So if you had 3 legths of metal capping,can you earth them together by drilling a hole in each length and linking them together with earth cable(what size cable please?)
It is currently Mon Jan 13, 2025 5:06 am
