Removing Door to Change Bottom Seal of Weatherstip
Old-But-Keen
by Old-But-Keen » Fri Apr 01, 2016 12:29 pm
Hi All, my first post so please be gentle
I found a piece of my bottom weatherstrip hanging from my door and decided it would be a good idea to pull the rubber strip out and replace it
However, I didn't take into consideration that at some time i would need to remove the door to turn it upside down in order to refit the strip
I am concerned about lifting the door off its hinges in case I break something and would ask for your help in reassuring me that this is the correct way to remove the door
I cant find a make on the door so attach to photos that may help
this has 3 hinges spaced equally
Re: Removing Door to Change Bottom Seal of Weatherstip
by welsh brickie » Fri Apr 01, 2016 10:01 pm
its the old flag hinges, open the door fully and simply lift it up, its on a pin system and refit the same way
Old-But-Keen
by Old-But-Keen » Fri Apr 01, 2016 11:49 pm
Thanks for your prompt reply. I will tackle this next weekend
Many thanks
It is currently Thu Jan 09, 2025 12:34 am
